Retired_Member
Jun 25, 2021remote backup
What do i input here? This computer is 300 miles from the readynas.
Jun 25, 2021Guru - Experienced User
Embedded pictures need to be reviewed by a mod before they are seen - that is part of the spam control in the forum.
What you need to do first is set up a VPN to reach the remote NAS. If the remote router supports openVPN, then you should set that up, and install the openVPN client on your PC. You could also use ZeroTier, or ReadyCloud.
After you get one of those working, you can post back and we can talk you through the rest of it.
