kht
Dec 10, 2013Aspirant
Remote replication
I have an AV company in London and i have a client who wants to replicate his music library in 2 locations. London and Hong Kong All the music is lossless and is about 1TB at the moment but increasin...
xeltros
Dec 10, 2013Apprentice
a two way rsync could do the trick I guess.
From what I know Rsync erase files only if the destination is older than the source when you use the update option. Problem is if he deletes domes files, then the --delete option will be a problem since if the first device do initiate the sync lack some files they'll be deleted from the other device too.
A quick research on "two way rsync" shows up a software called "unison", seems worth checking. (http://www.openlogic.com/wazi/bid/188061/ ) Didn't try but looks interesting.
