mediasurfer
Jun 20, 2016Tutor
Remote use of ReadyApp client for PC
Hi I am using a ReadyNAS 516 6-BAY Firmware 6.5.0 and I have migrated to the new single logon. I have it connected to a Virgin Media Super hub 2 and My PC runs Win 7 ultimate. I have installed t...
mediasurfer
Jun 21, 2016Tutor
Hi
I guess that will be the top and bottom of it. I am in the local administrator group on the PC but there is UAC (user application controll) running. Having said that the program
Installed with no errors and I was able to put my User/pw in the proxy settings. There will of course be firewalls, but I have no problems using the web portal?
- JennCJun 22, 2016NETGEAR Employee Retired
Hello mediasurfer,
Using the web portal is easier as that is an HTTP protocol that uses just web browser unlike the app that can be blocked and/or filtered by a firewall on the computer and of the network where the computer is. You mentioned something about proxy setting, are you meant to use that? What happens when under Network of ReadyCloud desktop client Settings you have all proxy boxes unticked?
Can you describe more please what exactly happens when you log in to the ReadyCloud desktop client?
- mediasurferJun 22, 2016Tutor
Hi
Thanks for your reply
At home no problem.
Using it here on my works PC (I'm working for an oil compamy and im actaully offshore just now) the program installs ok, When I sign in, after quite a delay, i get the message readyCLOUD server is unavaiable and the tray icon remains grey. I have tried with and without using my company logon details in the proxxy section.
Bear in mind i have to logon to this PC. I can surf the internet etc, no problem, but when using for example a digital TV listing program I have installed, in order to recieve updates I have to to ensure my company logon and password details have been entred in the programs proxxy settings otherwise it will not happen. (Internet explorer already has this info populated and picks up my logon autmatically without having to enter my password again)
- StephenBJun 22, 2016Guru - Experienced User
I am thinking that the corporate proxy only handles http and perhaps ftp. Do you know what kind of proxy it is? SOCKS or something else?
