G_man1
Jun 21, 2012Aspirant
Removing and replacing hard disk
I have an Ultra 2+ with 2 x 2TB Hitachi hard disk. Over the last few months I have been getting increasing SMART error's on disk 1. I decided to remove disk 1 and take it back to the store for warrant...
mdgm-ntgr
Jun 21, 2012NETGEAR Employee Retired
G man wrote:
Raid-ar is showng disk 1 as dead, is that normal?
Yes
G man wrote:
When I get the hard drive back and if my original data is still on the hard drive. Will it sync automatically if i have added data to disk 2?
Hot-add (add while NAS is on) and it will be wiped and added to the array.
G man wrote:
Should I format the hard drive before I plug it back in?
Don't format it. Delete the partitions on the disk.
