Dark_Stranger's avatar
Oct 19, 2017
Removing Raid
Guys, I have a ReadyNas Ultra 2 running 2 x 3TB disks configured to Raid 1.  I have now reached 99% capacity and as the contents is only movies, i dont really need the resiliance and want to have the NAS setup so that I have 6TB storage instead of a mirrored 3TB of storage.  I was planning on buying an external 3TB drive, copying the movies off the NAS, and reconfiguring the drive, but is there an easier way to free up the 3TB being used to duplicate my movies?
Thanks in advance,
Stu
1 Reply
  • StephenB's avatar
    No.  You need to destroy the existing volume, which will delete all the data.
    The best mode is to use JBOD (with 2 volumes).  If you create one 6 TB volume with RAID-0, then you will lose all your data when either disk fails.  That's a showstopper for me.  If you have 2 3TB volumes, then you only lose the data on the failed drive. You do need to roughly balance the storage across the two volumes, but in my opinion that is a small price to pay for the extra safety.
    Either way, I do suggest getting using a UPS with your NAS.  Many data loss stories begin with an unexpected power cut.
    FWIW, you might find it difficult to reconstruct your movie collection if (really when) you lose the volume.  Perhaps get a larger USB drive (or a second one), so you can keep your backup up to date.
ProSupport for Business
