kgfarrell
Jan 27, 2012Aspirant
repeated failure on same disk
I have a Readynas NV. DIsk 2 has failed 3 separate times. I am wondering if there can be a problem with the NV. Each time it has been a new drive added. The reallocated sector count will start incr...
mdgm-ntgr
Jan 27, 2012NETGEAR Employee Retired
Could you power down the NAS, remove the side panels and check the unit for dust. An excessive build up of dust could cause issues. Cleaning out dust may help.
