kgfarrell
Jan 27, 2012Aspirant
repeated failure on same disk
I have a Readynas NV. DIsk 2 has failed 3 separate times. I am wondering if there can be a problem with the NV. Each time it has been a new drive added. The reallocated sector count will start incr...
mdgm-ntgr
Jan 28, 2012NETGEAR Employee Retired
That is a good point. It could just be a bad run with failing drives just happening to be in the same slot. Checking the drive using SeaTools would be a good idea. If you still have the drives that failed earlier checking them as well would also be a good idea.
