kgfarrell
Jan 27, 2012Aspirant
repeated failure on same disk
I have a Readynas NV. DIsk 2 has failed 3 separate times. I am wondering if there can be a problem with the NV. Each time it has been a new drive added. The reallocated sector count will start incr...
Feb 02, 2012Guru - Experienced User
Might be worth running the SMART test. Also, look at the SMART parameters - vendor thresholds for pass/fail on reallocated sectors are higher than I'd like. BTW, I have never had Seagate or Western Digital question one of my returns.
