kgfarrell
Jan 27, 2012Aspirant
repeated failure on same disk
I have a Readynas NV. DIsk 2 has failed 3 separate times. I am wondering if there can be a problem with the NV. Each time it has been a new drive added. The reallocated sector count will start incr...
Feb 03, 2012Guru - Experienced User
How many reallocated sectors are reported in Seatools (you can access the SMART info, it is separate from the tests).
kgfarrell wrote: Both drives flagged as having excessive reallocated sectors passed the seatools long generic tests.
