steveoelliott
Jun 22, 2019Luminary
Replace / Hot Swap Disk - Device changed from SDB to SDE - Normal?
Hi Folks, I have a 526X with four drives in a RAID 6 array and due to some bad sectors on one of the drives I replaced it. It is currently syncing to the new disk but I notice that the device...
- Jun 22, 2019
steveoelliott wrote:
I'm assuming this is to be expected even though the replacement disk went into the same bay (2).
I just want to be sure this change of device name for the new drive won't cause any issues after reboot. I'm guesssing when rebooted the drive may get back it's sdb name.
This is normal (I saw the same thing when I replaced a disk a few weeks ago). It will go back to sdb when you reboot.
Jun 22, 2019Guru - Experienced User
steveoelliott
Thanks Stephen. I thought as much.
