norrispackard
May 28, 2018Tutor
Replace rn104 with?
Good day all. I would to Upgrade my rn104 with new one more powerful. On firts istance seems that the 214 should be the better solution. But I put eyes also on 4 series. I use the the Nas for home d...
- May 31, 2018
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marc_V
May 31, 2018NETGEAR Employee Retired
norrispackard
May 31, 2018Tutor
First, apologise for delay..
Second , thank for the answer, I had some doubt that spend money with the almost version had no sense and you solve my question.
I have intention to buy 424 model soon.... then thanks again.
Norris
Norris
