Joe-9O's avatar
Joe-9O
Replaced 4 NV+ RND4000 500GB with 2TB disks but there is no capacity increase
Hello,
I've replaced 4 x 500Gb disks with 4 2Tb disks (1 at a time).
However the volumes did not get expanded to reflect the added physical storage.
My understanding is that the volumes should have been automatically expanded after the last disk was added, initialised and sync'ed.
The firmware is the latest available revision:
Version: 4.1.16
Date:     Tue May 23 05:15:15 2017
Attached is the screenshot of the NV+ admin volume screen.
I'd appreciate any advice on this issue.
Thank you!!
Avinash
  • StephenB's avatar
    Try rebooting the NAS and see if expansion starts.
    • Joe-9O's avatar
      Joe-9O
      Thank you Stephen,
      I tried that with no luck.
      I also tried "Resync Volume"
      And I have presently rebooted with the "Check and Fix Quota" option selected.
      It is presently offline as it is doing this check.
      Thank you - Avinash
      • StephenB's avatar
        If that fails to solve it, then try enabling journaling and disabling disk spindown.  Then try rebooting with "check and fix Quota" a second time.
ProSupport for Business
