coondogg97
Jun 27, 2012Aspirant
Replaced my router and now I can not connect to ReadyNAS Pro
I switched out my Cisco routers for Mac Airports. Everything on my network is fine except I can not connect to the ReadyNAS through Windows. I can connect to the NAS through RAIDar fine, but not throu...
mdgm-ntgr
Jun 27, 2012NETGEAR Employee Retired
Glad the problem is solved.
You can monitor the NAS using RAIDar (http://www.readynas.com/downloads). If for some reason you accidentally chose to do a factory default you'd have 10 minutes to power down the NAS however you can to abort it.
