bct
Jan 02, 2013Tutor
Replaced one dying drive, now another is dead
Hello,
I have an Ultra 4 with 4x1TB Seagate drives.
For the last few weeks I've been getting email notifications regarding increasing ATA and SMART errors on drive #2. The warranty replacement drive arrived two days ago and I just swapped it with the OEM drive #2 yesterday. After the resync process, I got an email saying:
I checked in FrontView and the status shows drive #1 as dead and drive #2 as a spare. The home screen shows volume C: as being non-existant (more on that later.)
Here's the odd thing: when I reboot the NAS, FrontView will show drive #1 as being OK and it will show drive #2 as resyncing all over again and drive C: is accessible. But once I get the message about the resync finishing, drive #1 will show as dead again.
I don't care if the drive is dead, that'll just be the 3rd of the 4 OEM drives to fail on me, but I'm trying to understand the status and why it's doing what it is. Thanks!
RAID sync finished on volume C. The array is still in degraded mode, however. This can be caused by a disk sync failure or failed disks in a multi-parity disk array.
- mdgm-ntgrNETGEAR Employee RetiredDo you have an open support case? If not, please open one. Post your case number.
- bctTutorCase #20289045 opened tonight. (Waited until I could try a couple experiments and get my data backed-up - just to be safe.)
- bctTutorTurns out I was also having an issue with disk #1, but the ReadyNAS wasn't reporting it until after I did the sync with disk #2. Running a disk test from the boot menu confirmed it right away. Unfortunately, pulling out disk #1 after the sync had completed destroyed the volume… even though disk #1 worked if disk #2 was removed (so confused). So now I'm in the process of rebuilding my NAS setup. (Luckily my important data was backed-up.)
Though, even after a factory reset, with only 3x1TB drives, it says 50GB is being used. Is this space that it used for redundancy? I was never aware of it before.
