grintstick
Jun 21, 2017Aspirant
Replacement disk not recognised Readynas nv+ RND4000
I had 2 x 2TB drives in my nv+. One of the drives failed so I replaced it with a new drive. (Made sure its on compatibility list.) It's supposed to be hot swappable, but:
- When I place the new drive in the bay. The sync does not begin. It's not recognised in either Raidar or Frontview. In fact, it causes frontview to become completely unresponsive. The only way of getting frontview to work again is to rebool the nv+ with just the single working drive in it.
- I've tried powering down too and putting the drive in when powered down. But the nv+ just hangs on 'Booting...' forever (like 15hrs).
- I've also tested the drive on a windows machine and it works fine.
Could the nv+ itself be faulty or does anyone know anything else I can try?
thanks...
What drive model are you using?
- grintstickAspirant
I'm using a Seagate Barracuda
Code:
ST2000DM006 Barracuda
https://www.amazon.co.uk/gp/product/B01ICLGJF8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Thanks...
Can you try testing it again with seatools in a PC? There's a destructive "write zeros" test that might be more useful than the normal long SMART test.
