bschalck
Nov 08, 2022Follower
Replacement disks RN102 , from 1xTb to 2 x 4TB
Hy, I have a question . I have my RN102 since long times. This NAS is simple clean, and nice to use . I have 2 news Disks Seagate Ironwolf Pro 7200RPM. If a replace one NAS Disk ( 1TB ) wit...
- Nov 08, 2022
Assuming you are using a RAID1 configuration (either via XRAID or FlexRAID), then your best path is to unformat the drive (remove all partitions), then swap it out with power applied. In most cases, you can skip the unformatting and do a "format" within the NAS GUI, but that sometimes fails due to a partition type the NAS can't do anything with.
Note that you will not see any increase in available space until you swap out the second drive.
If you are using a JBOD or RAID0 configuration then, no, you cannot just swap out the drive.
Sandshark
Nov 08, 2022Sensei
