BusaBoy
Feb 02, 2011Aspirant
Replacement Fan (FAN-3) for ReadyNAS 1000S
Gang, Fan 3 on my ReadyNAS 1000s just took a dump (PART #: RNR1000S-FAN1 - I think). I called into NetGear and was told that unit is out of warranty and no longer supported. Can anyone tell me e...
mdgm-ntgr
Feb 09, 2011NETGEAR Employee Retired
The thing is though PapaBear that the 1000S is so old that you wouldn't even be able to open a tech support case for it, I think, so the forum is the only way to get help for those units.
Anyway it's good that BusaBoy found a replacement and was able to share his findings with the community here.
