Ney
Sep 04, 2013Aspirant
Replacement fan for Ultra 6
Hi, My fan on my Ultra 6 really sounds like it is starting a slow (and noisy) death. Netgear does not carry replacement fans for the chassis, so does anyone know of compatible fans (preferably low n...
fastfwd
Sep 04, 2013Virtuoso
Ney wrote: Hi,
My fan on my Ultra 6 really sounds like it is starting a slow (and noisy) death. Netgear does not carry replacement fans for the chassis, so does anyone know of compatible fans (preferably low noise) that suits the Ultra 6?
If the Ultra 6 uses the same 120mm 3-pin case fan as the Pro Pioneer, it's a Crown Electronics AGE12025B12M. A lot of four is available right now on Ebay for $24.99: http://www.ebay.com/itm/200948037184.
I replaced the AGE12025B12M in my Pro Pioneer with a Noctua NF-S12A FLX; Amazon sells that one for $19.25: http://www.amazon.com/dp/B00BEZKX8Y.
