Ney
Sep 04, 2013Aspirant
Replacement fan for Ultra 6
Hi, My fan on my Ultra 6 really sounds like it is starting a slow (and noisy) death. Netgear does not carry replacement fans for the chassis, so does anyone know of compatible fans (preferably low n...
Ney
Sep 09, 2013Aspirant
fastfwd wrote:
Ney wrote: Can anyone confirm if it is the same fan in the ultra and pro?
If you have visual access to the back of the NAS, you may be able to confirm it yourself: That fan will be mounted with its label facing out, so look through the rear-panel screen and see if you can read enough of its model number to tell whether it matches the model number I posted.
If you can shut down the NAS, even better: You can open it up and see exactly what model number the fan is. And while you're in there, you can blow out what's likely to be a huge amount of dust inside the chassis. If there's a lot of dust on the fan itself, it might just need cleaning, not replacement (but make sure when you blow out the dust not to spin the fan too quickly; over-revving a fan with compressed air is a quick way to kill its bearing).
I have a feeling that over-revving is what might have caused the bearings to die yes :? I'll shut it down and see if I can get the serial off the fan later today, but I think I tried to no avail earlier. Thanks.
