Ney
Sep 04, 2013Aspirant
Replacement fan for Ultra 6
Hi, My fan on my Ultra 6 really sounds like it is starting a slow (and noisy) death. Netgear does not carry replacement fans for the chassis, so does anyone know of compatible fans (preferably low n...
CitizenPlain
Apr 15, 2014Aspirant
Wanted to add to this thread since I ended up here Googling the problem initially, that I just successfully replaced a rattling/clicking case fan (the big one on the top) on my ReadyNAS Ultra 6 Plus with a Noctua NF-F12 PWM 120mm Case Fan. It works. It's quiet. It comes with a four-pin connector but it still plugs into the 3 pin connector the old fan was plugged into on the ReadyNAS. Is there a better or different fan that would work? Probably. I have no idea. This one seems fine.
It's kinda pricey for a case fan, but the quality seems to be great and considering how much I spent on the ReadyNAS and drives, it's pretty cheap comparatively. $32 on Newegg. Here's a link: http://www.newegg.com/Product/Product.aspx?Item=N82E16835608026
My enclosure was out of warranty. It was an easy installation. Just need a phillips screwdriver to remove the sides of the ReadyNAS enclosure, the plate the fan is screwed to, and the old fan. Great success.
