fondy
Jun 08, 2017Tutor
Replacement for Ultra 4
Hei.
My Ultra 4 with four Segate 2TB is 9 years these days. In these 9 years with no problem.
Last month two discs are dead suddenly. I thought I would buy four new WD Red discs and repla...
- Jun 08, 2017
The closest OS 6 model to what you have is an RN314. But the RN424 is the newest ReadyNAS 4-bay platform, so I'd check out prices on that one.
If budget is a big concern, you could also consider the RN214 - it's an arm-based unit that is about the same speed as the RN314 for file storage.
