SJMarty
Sep 12, 2013Aspirant
Replacement Hard Drive Compatibility
I have a ReadyNAS NV+ v1 with 4 x Seagate Barracuda ST31000520AS 1 TB, 5900 RPM drives in a single X-RAID set. I've had the NV+ for about 3.5 years. In those three years, I've experienced three bad ...
vandermerwe
Sep 12, 2013Master
Any drive is fine.
The WD red drives have good reports on the forum, and are quite cheap.
Seagate do a NAS drive too which is on the HCL for the newer readynas units and may appear on the legacy unit HCL, but you may be a bit reticent about Seagate I'd guess.
