jeromes58
Jan 16, 2019Aspirant
Replacement Hard Drives for NV+ V1 WD Gold WD20005FBYZ
I will be upgrading my four 9+ year old 1T WD10EADS-00L5B1 drives in my NV+ V1 unit. I am looking at four WD Gold drives model WD2005FBYZ. My NAS is at Raidiator 4.1.14. Block size is 16384, so ...
Jan 17, 2019Guru - Experienced User
Sandshark wrote:
I'm not sure why you would go with Gold on an NV+ instead of Red. You're going to get equal performance on them, and the Reds will run cooler.
The NV+ is limited by it's sparc processor, so I agree there won't be any performance gain with the Gold's. Personally I'd have gone with Reds.
Though the Golds should work.
jeromes58
Jan 17, 2019Aspirant
I picked the Enterprise drive (WD Gold) for reliability, not performance. The NV+ is my home backup device, with four 9+ year old 1T WD Green drives installed. I am hoping to get 9+ years out of the new drives, but time will tell.
I will report if the drives are compatiable or not with the NV+ V1 after they arrive.
