yfwong
Jan 22, 2012Aspirant
Replacement NV+ power supply? case #17743028
My NV+ power supply recently failed and I'm unable to locate a source where I can buy a replacement unit for it. The netgear store and amazon is out of stock. Are these power supply no longer manufact...
mdgm-ntgr
Jan 22, 2012NETGEAR Employee Retired
Is your serial number in this range?: http://www.readynas.com/forum/viewtopic.php?t=10259
If so depending what region you are in you may qualify for a PSU replacement even if the unit is out of warranty.
When did you purchase your NV+? Was it purchased brand new on/after Aug 21, 2007? If so it would still be under warranty. From August 21, 2007 to sometime in 2009(?) I think the warranty on new purchases of the NV+ was 5 years. It then changed to 3 years for new purchases.
Contact tech support (http://www.readynas.com/support)
You would need to migrate your disks to another Sparc ReadyNAS e.g. NV+ v1 (How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2, should you wish to migrate your disks to another unit. See http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
