Floob1
Jul 31, 2012Aspirant
Replacement Power Supply for ReadyNAS NVX? Case #19099497
Hi, It seems as though the power supply on our NVX ReadyNAS (RNDX4210) has failed. Where can I buy a replacement from that will be ok in the unit? Regards, Floob.
Floob1
Hi,
I have raised a case with Netgear, but they dont have any replacement units in stock, so it will be several days before a replacement is available - I thought a Power Supply replacement may be a quicker option.
I bought this about Q1 2010, and yes, I dont think it is the Pioneer version.
I'm fairly sure its an Intel based model, so I will also try putting the disks in a spare Ultra2 we have. The NAS says it is a NAS NVX on the side.
I will add my case number in the subject. I'm fairly sure the RAIDiator was the latest but one - although I forget the version number.
Shame I cant seem to source a spare PSU.
