Floob1
Jul 31, 2012Aspirant
Replacement Power Supply for ReadyNAS NVX? Case #19099497
Hi, It seems as though the power supply on our NVX ReadyNAS (RNDX4210) has failed. Where can I buy a replacement from that will be ok in the unit? Regards, Floob.
OOM-9
Jul 31, 2012NETGEAR Expert
You can move the disks from the NVX to Ultra with no issues. There will be some features missing from the GUI, but that is because you are coming from the NVX (Business) to Ultra.
I will check on the support side to see if we are able to get the NVX RMA'd with the correct unit.
Note: I have check the registration and it looks like you have the NVX Business unit.
