Floob1
Jul 31, 2012Aspirant
Replacement Power Supply for ReadyNAS NVX? Case #19099497
Hi, It seems as though the power supply on our NVX ReadyNAS (RNDX4210) has failed. Where can I buy a replacement from that will be ok in the unit? Regards, Floob.
Floob1
Hi,
That is great news that you think from NVX to Ultra will be ok, fingers crossed when we do this tomorrow.
Thanks very much for your help.
I have been told by support to run the OS reinstall (no.3 on link below) on the Ultra before powering it up proper with the NVX disks in. Would you agree?
http://www.readynas.com/kb/faq/boot/how ... _boot_menu
