Floob1
Jul 31, 2012Aspirant
Replacement Power Supply for ReadyNAS NVX? Case #19099497
Hi, It seems as though the power supply on our NVX ReadyNAS (RNDX4210) has failed. Where can I buy a replacement from that will be ok in the unit? Regards, Floob.
OOM-9
Jul 31, 2012NETGEAR Expert
That should be okay. The firmware that is loaded to the disks with be the same...
Do you know what firmware that you had on your NVX and Ultra?
There are some possible issues you would run into if you are running an OS Reinstall on firmwares that are different. (eg. OS Reinstall with a unit that has 4.2.5 on the flash may have issues if the disks are running 4.2.21.)
