Floob1
Jul 31, 2012Aspirant
Replacement Power Supply for ReadyNAS NVX? Case #19099497
Hi, It seems as though the power supply on our NVX ReadyNAS (RNDX4210) has failed. Where can I buy a replacement from that will be ok in the unit? Regards, Floob.
Floob1
Hi,
The Ultra2 has RAIDiator 4.2.21 installed, but the NVX had 4.2.19 (I think - certainly not newer anyway).
On that basis should I run the OS re-install or not?
In addition, the NVX had 2 disks in 4 bays (2 were empty). Can I take just one of these disks and put it into the Ultra2, or must I put both disks straight in?
