Floob1
Jul 31, 2012Aspirant
Replacement Power Supply for ReadyNAS NVX? Case #19099497
Hi, It seems as though the power supply on our NVX ReadyNAS (RNDX4210) has failed. Where can I buy a replacement from that will be ok in the unit? Regards, Floob.
OOM-9
Jul 31, 2012NETGEAR Expert
The firmwares are relatively close and you can do an OS reinstall without harm.
It is recommended to have all the disks in, so you should be good to migrate over to the Ultra.
