Floob1
Jul 31, 2012Aspirant
Replacement Power Supply for ReadyNAS NVX? Case #19099497
Hi, It seems as though the power supply on our NVX ReadyNAS (RNDX4210) has failed. Where can I buy a replacement from that will be ok in the unit? Regards, Floob.
Floob1
Aug 01, 2012Aspirant
Netgear have now said they will ship a Pro 4 instead (which I assume is x86 based) and that I wont need to do an os-reinstall?
To be honest I'm not too clear on why an os-install would or wouldn't be required in my situation?
I would like to be in the position where I could get the Pro 4 being sent and just put in the 2 disks I have - hopefully the NAS wont try to format or otherwise initialize them again.
