Floob1
Jul 31, 2012Aspirant
Replacement Power Supply for ReadyNAS NVX? Case #19099497
Hi, It seems as though the power supply on our NVX ReadyNAS (RNDX4210) has failed. Where can I buy a replacement from that will be ok in the unit? Regards, Floob.
Floob1
Aug 01, 2012Aspirant
Thanks for that.
What if the pro 4 comes with a firmware newer than I had on the NVX?
I believe the NVX had 4.2.19 or 4.2.20 on it.
