kalpsr
Oct 11, 2013Aspirant
Replacing 2Tb Seagate Hdd with 3/4 Tb Disks
i have to upgrade storage in one of ReadyNas Pro at our company. its RNDP6000 with 6 Seagate Hdds each of 2Tb in XRaid. Please guide me about the process of replacing the Hdds. i would like to use 3tb...
fastfwd
Nov 16, 2013Virtuoso
Camelxx, you mentioned the 3TB WD Red drives in an earlier post, then you began asking about 4TB drives but did not specify a model.
The 3TB Red drives (model WD30EFRX) apparently work fine, but the 4TB Red drives (model WD40EFRX) have a problem at the moment that makes them unsuitable for use in a ReadyNAS Pro. If you want 4TB drives, I would suggest choosing another model unless you can confirm that the problem with the Red drives has been fixed.
Problem details are here: https://www.readynas.com/forum/viewtopic.php?f=24&t=73417
