kalpsr
Oct 11, 2013Aspirant
Replacing 2Tb Seagate Hdd with 3/4 Tb Disks
i have to upgrade storage in one of ReadyNas Pro at our company. its RNDP6000 with 6 Seagate Hdds each of 2Tb in XRaid. Please guide me about the process of replacing the Hdds. i would like to use 3tb...
Nov 27, 2013Guru - Experienced User
It still be in the log files. I don't know of any other way to tell.
BotanyBay wrote: I started with 750GB hard drives but it may have been less than the full six. Is there any way to determine what the original configuration was? Or what the limit for the current expansion is?
Yes to both, keeping in mind that you are using TB, not TiB. Your current config is ~8.5 TB
BotanyBay wrote: If I started with 6 drives that would give a volume of about 3.75 originally so I could expand to 11.75?
If I started with 3 drives that would be a volume of about 1.5 originally so I could expand to 9.5?
I'm running 4.2.24 with no issues. There are some significant security fixes in it that you don't have.
BotanyBay wrote: Current firmware is 4.2.19 (if looking for the most stable build should I go ahead and come up to the 4.2.24? I have been looking for any issues which that build might have)
