mbrown375
Jan 03, 2017Follower
Replacing a ReadyNAS ReadyNAS NV+ RND4410
I am looking to add to a system that has ReadyNAS NV+ RND4410 and would like to get a larger capacity unit. What is compatible with what I already have? thanks
Jan 03, 2017Guru - Experienced User
What exactly do you mean by "compatible" I have an NV+ that coexists with my OS 6 ReadyNAS (526x) quite happily. Both can be accessed from Windows, etc, and the NV+ backs up some shares on the 526x using rsync. That could also be done with other protocols (NFS or CIFS), rsync is my preference. For me that's compatible enough.
But I can't migrate disks from the NV+ to the 526x and preserve the data - at least not without help from support. http://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6
