ddoming73
May 05, 2013Tutor
Replacing Pro Pioneer Motherboard. Is it worth it?
My Pro Pioneer recently died. After turning it on (power switch on the back) you get no activity at all except some feeble flashing on the LAN1 LEDs. After some troubleshooting, I 'm thinking the P...
chirpa
May 09, 2013Luminary
If I was still at NTGR, I would have hooked you up. But not many left there that care to do that. I'll check around though.
Either way, good luck with Mike.
