irarosenstudio
Oct 28, 2016Aspirant
replacing some of the disks inserted to ReadyNAS NV+
I have older ReadyNas NV+ model RND4000.
They came with 4x750 gig drives. I called Netgear and they said I could upgrade my drives to 2TB each and recommended the following number
Seagate Bar...
- Nov 28, 2016
Hello irarosenstudio,
What does it show under Volume Settings?
Oct 28, 2016Guru - Experienced User
The NV+ can handle 2 TB drives.
Likely your firmware is very old - what firmware are you running?
- irarosenstudioOct 28, 2016Aspirant
Thanks! I have whatever came installed in the unit. How do I go about updating firmware?
Ira
- StephenBOct 28, 2016Guru - Experienced User
Start by posting the firmware you are running now. RAIDar can see it, and you can also see it on the home page of the admin web ui.
- irarosenstudioOct 31, 2016Aspirant
3.01c1-p6
I believe thats the version?
Does that sound right?
Thanks again,
Ira
