irarosenstudio
Oct 28, 2016Aspirant
replacing some of the disks inserted to ReadyNAS NV+
I have older ReadyNas NV+ model RND4000.
They came with 4x750 gig drives. I called Netgear and they said I could upgrade my drives to 2TB each and recommended the following number
Seagate Bar...
- Nov 28, 2016
Hello irarosenstudio,
What does it show under Volume Settings?
irarosenstudio
Thanks! I have whatever came installed in the unit. How do I go about updating firmware?
Ira
Oct 28, 2016Guru - Experienced User
Start by posting the firmware you are running now. RAIDar can see it, and you can also see it on the home page of the admin web ui.
- irarosenstudioOct 31, 2016Aspirant
3.01c1-p6
I believe thats the version?
Does that sound right?
Thanks again,
Ira
- StephenBOct 31, 2016Guru - Experienced User
irarosenstudio wrote:
3.01c1-p6
Ok, that's the problem. You are running ancient 3.x firmware, and that doesn't handle 2 TB drives. You'll need to upgrade to 4.1.15.
That's a big jump - I recommend manually downloading 4.1.8, and installing that first. Then after that completes, do a factory reset. Then upgrade to 4.1.15.
The factory reset is because Netgear changed the disk partitioning in 4.1.7 to improve performance with larger drives. You need to do a reset to take advantage of that change.
4.1.8 is from http://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator-4.1.8.zip
4.1.15 is here: http://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator-4.1.15.zip
You'll need to extract the binary image from the zip file before uploading it.
- irarosenstudioNov 01, 2016Aspirant
sounds great, thanks so much! one last question... i've two of these systems running and one of them i don't want to mess with. will upgrading the firmware effect both or only the one i direct it to?
ira
