kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
Staffan1
Have not done a fan replacement but should be possible if you find one that has enough airflow and are the right size.
It would be a great help if one had the airflow specification of the original fan.
.staffan
.staffan
