kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
jraneses
In looking at possible replacement fans for the Duo on Newegg, these models might be viable candidates. In my opinion, it's not so much the noise level of the Duo that's the problem, it's the tone of the stock Crown fan.
VANTEC TF6025
http://www.newegg.com/Product/Product.a ... 6811999615
Dynatron DF126025PL-3/4G
http://www.newegg.com/Product/Product.a ... 6835114064
Those are the top 2 rated 60mm fans from the product category
http://www.newegg.com/Product/ProductLi ... rchInDesc=
Can any of the Jedi's comment on the compatibility of the replacement fans listed above?
Thanks,
Jason
VANTEC TF6025
Thanks,
Jason
