kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
Staffan1
Oct 30, 2008Aspirant
I suggest that you at least get the same airflow value on the fan. Then you should be safe when it comes to the components.
.staffan
.staffan
