kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
kwantai
Oct 30, 2008Aspirant
Mechanix wrote:
kwantai wrote:
Staffan wrote: I suggest that you at least get the same airflow value on the fan. Then you should be safe when it comes to the components.
.staffan
True. The new fan has a CFM of 27 m³/h, which seems to be higher than the original fan... I hope I'm safe :)
Hi,
i have a couple of questions:
Which model is currently in the duo?
What´s the impact on the temperatures. Did you noticed any improvement?
I have 2 500GB HDD´s in my duo and the temperatures with the original fan are for both HDD´s 44-46 °C
I planing in fact to use this fan:
http://www.papst.de/index/sid/30B11206- ... rent_id%3D
jraneses wrote: This is the fan currently in the Duo:
http://www.crownelectronics.com.tw/Serpro/AGE06025.pdf
I'm also considering swapping it out with a compatible, lower CFM model.
I don't know what the temperature was before, but right now I have 2 500GB HDD with one on 43 C temp and the other at 36 C. The NAS has been powered in all day and music has been playing from one of the HDD now for at least 5 hours.
Fan 1 1923 RPM
I believe the Papst fan will work good.
