kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
kevinl1886
Nov 07, 2008Aspirant
I removed 4 small screws on the back. The case seems to stuck in place and will not come off. Did I missed something here? Do I need to remove the front door to get the case off? Need some help on the steps. Thanks
