kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
toddel68
Nov 08, 2008Aspirant
Mechanix wrote:
You have to pull the side panels. They slide out easly
To be precise you need to slide them to the side (backwards). Then you can access the other screws to release the back panel. The rest is self explanatory.
If you would remove the front door it would take you to remove another 13 screws ;-)
