kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
NASNoob11
Jan 07, 2009Aspirant
dooku wrote: Keep in mind that replacing the fan will void your warranty.
dooku,
Can you please state why replacing a failed cooling fan in a ReadyNAS will void my warranty? Can you please point me to a Cooling Fan Hdw Compatibility List I can use for shopping?
My ReadyNAS has been installed/online for 6 weeks and the cooling fan can be heard all over the house!
Perhaps you can share a link to the "I need a replacement cooling fan!" area at NetGear? I can not find same.
I do not wish to kill my warranty. But, trying to sleep with the current howling "Crown" cooling fan is getting very old................ :|
I have been a satisfied NetGear user for the past 10 years. This current ReadyNAS RD2150 may probably outlive me.............. :)
Thank you very much.
Duncan
