kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
NASNoob11
Jan 07, 2009Aspirant
dooku wrote: the reason that replacing the cooling fan might void your warranty is because each fan is different and has different CFM, if you replace the fan with a quieter fan it might push less air through and cause the unit to overheat.
I am sorry but currently we do not have a list of third party compatible fans.
dooku,
Thank you. I understand this position. I plan to use a fan that has an equal or greater CFM as a replacement. I have found 2. I will test both for "noise." No harm, no foul! :D
