kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
Ennio1
Apr 22, 2009Aspirant
This is mine, with a Nexus fan.
Look here for specs and here for 80mm fan review.
I used sillicone kit to mount the sides of it to the back. Removed the Crown fan from inside.
Runs really cool and silent now @~1200 RPM. Harddisks never hotter than 29 degrees Celsius;
