kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
jhvl
May 18, 2009Aspirant
Hi
New user here... I have been looking at this fan:
http://www.acousticpc.com/acoustiproducts_60mm_dust_proof_acousti_fan.html
Looks like it will be much more quite than the original one, plus it should fit perfectly as it is 60x60 mm. But it is a bit expensive. Any thoughts on this one?
/j.
/j.
