kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
marvids
Jun 02, 2009Aspirant
Has anyone checked out the SCYTHE MINI KAZE 60MM (http://www.dustinhome.se/pd_5010315358.aspx)?
36 CFM and 20 dB
It seems though that it is fixed to 2500 rpm, but maybe that's good (constant noise)
36 CFM and 20 dB
