kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
swisstony
Jun 15, 2009Aspirant
I checked my fan and it has part number age06025B12h. The Readynas was bought in Swtzerland in November 2008. This fan is mentioned in the data sheets where it says it has a max air flow of 25.2 CFM and a dba of 33 at max rpm:
Part NO. B / S / F V V A RPM m3/min CFM mm-H2O In-H2O dBA g
AGE06025_12H B S 2 7.0~13.8 0.25 5,000 0.726 25.62 6.48 0.26 33 57
I'm tempted to replace it with a larger fan or quieter 60mm fan but i'm unsure about the variable speed part. With the stock fan there is a speed element to it - it spins at 5000 rpm when first turned on and then idles at about 1700rpm. I have never seen it run faster than 1700 after the initial start up. Does it automatically speed up if the temperature rises?
I have a 120mm quiet case fan with the same amp rating and better flow.. but i dont know if it is variable speed..
regards
swisstony
edited for spelling
regards
swisstony
edited for spelling
